Activity Forums Adobe After Effects Choke and invert a silhouette layer?
  • Choke and invert a silhouette layer?
    Posted by Eric Chard on June 19, 2015 at 9:10 pm
    Working towards a solution to a situation….
    I’d like to use a layer as a silhouette layer, but with this proviso:
    I’d like to choke the alpha of the silhouette, so it’s slightly smaller, and then
    Invert the alpha.
    How would one go about that?
    “Putting the HARM in ‘harmonica’ since 2005.”
    Richard Herd replied 11 years, 3 months ago 3 Members · 2 Replies
  • John Cuevas
    June 20, 2015 at 2:52 pm
    I’d choke the layer & precomp it. Place a solid below that chocked layer and set it’s track matte to “Alpha Inverted”. Then in the final comp use the precomp as the silhouette layer.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Herd
    June 22, 2015 at 3:17 pm
    [John Cuevas] “I’d choke the layer & precomp it. Place a solid below that chocked layer and set it’s track matte to “Alpha Inverted”. Then in the final comp use the precomp as the silhouette layer.”
    Also applying a fast blur smooths sharp edges.
