Activity Forums Apple Final Cut Pro Legacy choices for complete reinstall
  • choices for complete reinstall
    Posted by Chris Gorman on February 8, 2010 at 5:24 pm
    I’m starting the long process of a clean reinstall of everything and manually doing all the updates back up to OSX.4.11 and FCPS.2
    I have a good working cc clone on 2 other hard drives. Should I try to bring that over to a clean erased drive and save the time and effort of step by step reinstall and update of everything?
    If so, what’s the best way to bring it over?
    PowerPC G5 DP2.3, 4GB DDR SDRAM, ATI X800XT, OSX.4.11, QT 7.5.5, FCStudio2, FCP 6.0.5 Sonnet 5 Bay SATA (RAID or JBOD as needed), ACD 23″ & Sony NTSC Monitor via Matrox v.1
    Sony ZIU hdv, edit w.ProRes
    Chris Gorman replied 16 years, 7 months ago 2 Members · 4 Replies
  • David Roth weiss
    February 8, 2010 at 5:45 pm
    [chris gorman] “I have a good working cc clone on 2 other hard drives. Should I try to bring that over to a clean erased drive and save the time and effort of step by step reinstall and update of everything?”
    Chris,
    If you’re saying that one of your clones is essentially a new clean installation of the OS and FCS, then yes you should absolutely use it to save time.
    What you would do in that situation is boot to that clone, then clone it over to the erased system drive in your computer. Make sense?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Chris Gorman
    February 8, 2010 at 5:59 pm
    Thanks, only problem is that it’s been so long I don’t remember if it was a clean install or clone. If it’s a clone, does that mean I can’t clone it back over?
  • David Roth weiss
    February 8, 2010 at 6:07 pm
    [chris gorman] “If it’s a clone, does that mean I can’t clone it back over? “
    No, I was just suggesting that if your intention was to make an absolutely clean install then cloning that over to your system drive makes a perfect install.
    You see, I have no idea why you’re doing this install, and I’m just not wanting you to clone any problems back to your computer.
    If you know that your computer was operating well when that clone was made, then you might as well just clone it back to the system drive to save time.
    David Roth Weiss
    Los Angeles
  • Chris Gorman
    February 8, 2010 at 6:38 pm
    when i made the clone all was working good, much later unfixable problems started on my usual working drive. so i’ll try just cloning the good one over onto the erased hd. thanks.
