Activity Forums Adobe After Effects chisled text in AE
  • chisled text in AE
    Posted by John Carrington on June 26, 2008 at 6:19 pm
    I need to make text look like it is ‘set’ into 2 stone tablets, think ten commandments.
    I have tried quite a few different ways but nothing is really looking like its deep into it.
    any suggestions would be appreciated thanks guys, I will keep working on it also
    John Carrington replied 18 years, 2 months ago 2 Members · 3 Replies
  • John Carrington
    June 26, 2008 at 7:20 pm
    Dave I knew i could count on you……I will try that out, I think that my text was a bit thin, thanks again
  • David Rickles
    July 3, 2008 at 5:47 am
    Another possible solution that will carry your textures through would be to pre-comp your text and apply CC Glass to your “stone”. This by playing with the settings, you will be able to get a desired effect and should be able to make it as chiseled as you desire. Andrew Kramar did a tutorial that similar recently, #65 on AE Bumpmaps, recently… Hope that may help in some way!
    David Rickles
    Producer, Editor, Animator
    David.Rickles@gmail.com
    http://www.davidrickles.com
  • John Carrington
    July 3, 2008 at 5:15 pm
    Thanks David, Thats actually what I ended up using and it looked pretty good, but in the end we decided to go a different direction with the design, but now i know how to do it so that in the future I wont have a problem or if someone else needs help with it
