Activity Forums Adobe Audition Chirping S
  • Chirping S
    Posted by Dan Plonsker on September 29, 2006 at 8:06 am
    Hello all,
    I have a narration recording with a problem of sort of chirping noise when an S or Z are pronounced. Is there a filter to correct it?
    Willie Toth replied 19 years, 11 months ago 2 Members · 5 Replies
  • Willie Toth
    September 29, 2006 at 11:38 am
    When you record there is a POP filter you use that is a fine meshed material simular to panty hose that is placed in front of the mic … As far as removing it after it’s recorded and keep the integraty of the audio may not be possible …………. WILLIE
  • Dan Plonsker
    September 29, 2006 at 11:55 am
    Thanks Willie,
    I’m looking for post recording something…
  • Willie Toth
    September 29, 2006 at 12:40 pm
    Dan,
    If you want E-mail me a sample and I will see if I can head you in the right direction … E-mail to loganonestudio@aol.com …… WILLIE
  • Dan Plonsker
    September 30, 2006 at 5:37 am
    Thanks Willie,
    I went to a recording studio here and they used a filter (I think it was something like d10 or dx10 – have to check with them again)which cleaned it a bit.
  • Willie Toth
    September 30, 2006 at 9:48 am
    Dan,
    Proper diction can be an assest as well … The critical letters P, S, and in your case Z … Here is a link for a good affordable Pop filter ……. WILLIE
    https://www.americanmusical.com/item–i-RAX-POMT–m-6_356_571.html
