Activity Forums Adobe Premiere Pro Chenging Multiple Title Clips Text Properties?
  • Chenging Multiple Title Clips Text Properties?
    Posted by Gabi Bucataru on June 12, 2013 at 4:32 pm
    Hi Gang!
    So, a quick one. I was told in the 12th hour that I need to change the titles I have in my movie (and I have a LOT!) from a yellow text color to green.
    They all are separate Title instances on the timeline.
    I tried selecting them all in the timeline and changing the color, but only the first selected clip was altered.
    Is there something I’m missing?
    thanks!
    Gabi.
    Gabi Bucataru replied 13 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Kris Merkel
    June 12, 2013 at 6:34 pm
    Not in the text editor, A work around would be to lay off your titles into a separate sequence and apply an adjustment layer to change the color and then nest the sequence back into the cut.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Gabi Bucataru
    June 12, 2013 at 6:40 pm
    Good point about the adjustment layer, Kris!!
    thanks a ton!
    gabi
  • Bret Williams
    June 12, 2013 at 11:53 pm
    I’ve been asking for this sort of thing in FCP legacy for years. Finally implemented on FCP X. You can highlight all your titles and change their font, color, size, etc. you can also do a search and replace text function.
    Very handy when something is misspelled in hundreds of captions!
  • Gabi Bucataru
    June 13, 2013 at 1:28 am
    Thanks Bret –
    that’s great for FCP. But we are into Adobe PrPro 🙁
    thanks,
    g
  • Bret Williams
    June 13, 2013 at 3:35 am
    Just making conversation. Still learning PPro and awaiting the new CC version before running through some real projects with it.
  • Kris Merkel
    June 13, 2013 at 2:48 pm
    For conversations sake, One way to do this would be to create a master comp in AE with text attributes and the make pre comps for each text element and then use Dynamic Link to add those pre-comps to the PrPro Project. than if you need to change any of the global atributes you can update the Master comp in AE and it will procedurally change all of the elements.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Gabi Bucataru
    June 18, 2013 at 4:29 pm
    Good point Kris!
    It might be overkill, but it sure comes in handy when the customer says that they want a different color text 🙂
    Gabi
