checking cadence in final cut pro
I’ve shot 24P and uploaded footage into FCP using standard 23:97. Does anyone know how to now check the entire film to make sure that the 2:3 cadence is not interrupted by the edits? ie. 2:3:3:2 is the regular cadence, how do I make sure an edit doesn’t make it go 2:3:3:3:2:2:3?
How do I extend each cut so I can tell it will then go 2:3:3:2:2:3:3:2?I’d greatly appreciate any help.
