Activity › Forums › Adobe After Effects Expressions › Checkbox to select X value or Y Value of a Layer
  • Checkbox to select X value or Y Value of a Layer
    Posted by Kevin Snyder on March 3, 2016 at 5:54 pm
    I don’t know if this is possible, but here is a line in my expression that is giving me trouble.
    x=effect(“(S) Layer Control”)(“Layer”).(effect(“Checkbox Control”)(“Checkbox”)==1) .transform.yPosition else .transform.xPosition);
    I am using layer control to select a layer and I want to use a checkbox to determine whether or not it uses data from the position X value or Y value. Any help to get me going in the right direction would be great. Thanks.
    Kevin
    David Conklin replied 10 years, 7 months ago 2 Members · 3 Replies
  • David Conklin
    March 3, 2016 at 6:11 pm
    Something like this should work.
    Change the 2 variables at the top to point to your Layer and Checkbox controls. This expression will output the X-Value of the Layer Control Layer if the box is un-ticked, and the Y-Value if it is ticked.
    var lyrControl = thisLayer("Effects")("Layer Control")("Layer");
    var chkbxControl = thisLayer("Effects")("Checkbox Control")("Checkbox");
    if(!chkbxControl.value){
    lyrControl.position[0]; // use X-position.
    } else {
    lyrControl.position[1]; // use Y-Position
    David Conklin
    Motion Designer
  • Kevin Snyder
    March 3, 2016 at 6:39 pm
    Thanks David for the input. I appreciate it.
    I’m getting an error stating an illegal use of a reserved word. Here is the full expression that I have. I have it working without the check box, but I would love to get it working with the check box to select the x or y value. The overall goal is to select a parent and then map the x or y value to the scale of my “child” layer using sliders to define the range of the parent and the range of the scale for the child… I think I might be in over my head on this one…
    x = var lyrControl = thisLayer("Effects")("Parent Select")("Layer");
    var chkbxControl = thisLayer("Effects")("Map")("Checkbox");
    {lyrControl.position[0]; // use X-position.}
    else
    {lyrControl.position[1]; // use Y-Position}
    scaleobject=linear(x,effect("Parent Input 02")("Slider"),effect("Parent Input 01")("Slider"),effect("Child Output 02")("Slider"), effect("Child Output 01")("Slider"));
    [scaleobject,effect("Fixed Scale")("Slider")]
  • David Conklin
    March 3, 2016 at 7:54 pm
    Hey.
    In re-purposing my code, I think some typing/syntax errors may have occurred. For instance on line 1, you have ‘x = var lyrControl = thisLayer’. I think you need to retype this as ‘var lyrControl = thisLayer’ or ‘var x = thisLayer’.
    Syntax errors also exist on lines 6 and 10, where the ‘//’ (signifying a comment) have caused the closing curly brace to not be computed.
    I’ve re-typed the code below. I can’t check it because I don’t have your project setup; however, it is evaluating without syntax errors.
    Good luck!
    var x = thisLayer("Effects")("Parent Select")("Layer");
    x.position[0]; // use X-position.
    else{
    x.position[1]; // use Y-Position
    scaleobject=linear( x, effect("Parent Input 02")("Slider"), effect("Parent Input 01")("Slider"), effect("Child Output 02")("Slider"), effect("Child Output 01")("Slider"));
    David Conklin
    Motion Designer
