Activity Forums Adobe After Effects Expressions Checkbox controlling 2 different sets of array possibilities – Error
  • Checkbox controlling 2 different sets of array possibilities – Error
    Posted by Jason Hearne on February 3, 2012 at 8:10 pm
    I’m trying to control the position of null based on if it’s being controlled by a slider or not.
    If it’s controlled by the slider – It moves.
    If it’s not controlled by the slider it returns to it’s default position and does not move.
    I get the “Dimension error” 1 instead of 3
    I’m searching all over the place and I can’t figure out why this does not make sense?!?!
    control = effect("Checkbox Control")("Checkbox") ;
    xoffset=thisComp.layer("Camera Controls").effect("Mosaic Mover X")("Slider")*30;
    yoffset=thisComp.layer("Camera Controls").effect("Mosaic Mover Y")("Slider")*20;
    x=parent.position.value[0];
    y=parent.position.value[1];
    z=parent.position.value[2];
    if (control == 0){
    [x+xoffset,y+yoffset,z];
    }else{
    [x,y,z];
    Jason Hearne
    EdenFX
    Visual Effects and Animation
    Paul Roper replied 14 years, 7 months ago 2 Members · 4 Replies
  • Paul Roper
    February 3, 2012 at 8:17 pm
    Not sure, but try removing the semicolons fro the end of the [x+xoffset,y+yoffset,z]; and [x,y,z]; lines. I might be wrong, but it’s worth a shot.
    – Paul
  • Jason Hearne
    February 3, 2012 at 10:04 pm
    Yeah, I thought of that prior to posting. Just tried it again to make sure I wasn’t crazy… yup, not crazy.
    sigh
    Jason Hearne
    EdenFX
  • Jason Hearne
    February 3, 2012 at 10:25 pm
    Holy Guacamole!!!
    I was putting it on the wrong layer….
    I reduced it to 1 dimension like it was asking for, and once I no longer got the error, I could not change the value. That’s when I knew I had it on the wrong layer… ugh.
    Thanks anyway, Paul.
    J
    Jason Hearne
    EdenFX
  • Paul Roper
    February 3, 2012 at 10:32 pm
    Hmm….I’ve just tested that expression and it doesn’t generate any errors for me – it evaluates OK, but I’m not sure exactly what you’re trying to achieve by it. If you want the checkbox to control whether or not the………………….
    ….ah – just seen you’ve solved it!
