Activity Forums Adobe After Effects Expressions Checkbox Controlled Opacity
  • Checkbox Controlled Opacity
    Posted by Danni Runitz on November 2, 2020 at 9:41 am
    Hey!
    I’m new to expressisons.
    With the checkbox I can control the opacity on and off the this expressison.
    “if(thisComp.layer(“Adjustment Layer 4”).effect(“Checkbox Control”)(“Checkbox”)==1) 100 else 0″
    But I want more control. So if the checkbox is off the layers opacity is 0, but when the checkbox is on I want to use the layers keyframes on opacity. Is that possible?
    Danni Runitz replied 5 years, 10 months ago 2 Members · 5 Replies
  • Dan Ebberts
    November 2, 2020 at 11:00 am
    Try it like this:
    thisComp.layer("Adjustment Layer 4").effect("Checkbox Control")("Checkbox")==1 ? value else 0
  • Danni Runitz
    November 2, 2020 at 11:40 am
    Thanks dan!
    Made it work with this:
    if(thisComp.layer(“Adjustment Layer 4”).effect(“Checkbox Control”)(“Checkbox”)==1) value else 0
  • Danni Runitz
    November 2, 2020 at 11:54 am
    Okay. What if I want to go more advanced.
    So “on” only uses the 2 first keyframes and “off” only use the 2 last ones?
  • Dan Ebberts
    November 2, 2020 at 4:26 pm
    >Made it work with this:…
    A single-line if/else like that will only work with the Legacy ExtendScript engine (or an old version of AE).
    >What if I want to go more advanced…
    Try this:
    cb = thisComp.layer("Adjustment Layer 4").effect("Checkbox Control")("Checkbox");
    if (numKeys > 3){
    if (cb.numKeys > 0){
    n = cb.nearestKey(time).index;
    if (time < cb.key(n).time) n--;
    if (n > 0){
    t = time - cb.key(n).time;
    if (cb.value){
    t1 = key(1).time;
    t2 = key(2).time;
    }else{
    t1 = key(3).time;
    t2 = key(4).time;
    tt = linear(t,0,t2-t1,t1,t2);
    }else{
    tt = (cb.value) ? key(1).time : key(3).time;
    }else{
    valueAtTime(tt);
    }else{
    cb.value ? value : 0;
  • Danni Runitz
    November 3, 2020 at 8:27 am
    Waow Dan! Thank you so much. Everything is working
