Activity Forums Adobe After Effects Expressions Check to see if var is in array
  • Check to see if var is in array
    Posted by Edward Clayton on July 14, 2022 at 8:10 pm
    I’m working on an expression to determine the type (lowercase, uppercase, number, symbol) of the last character in a string.
    Right now I’m doing something like this
    par = parent.text.sourceText;
    src = par.charAt(par.length-1);
    lib = ["a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m", "n", "o", "p", "q", "r", "s", "t", "u", "v", "w", "x", "y", "z"];
    libNum = ["1", "2", "3", "4", "5", "6", "7", "8", "9", "0", "-", "/", ":", ";", "(", ")", "$", "&", "@", '"', '“', '”', ".", ",", "?", "!", "'", "’"];
    libSym = ["[", "]", "{", "}", "#", "%", "^", "*", "+", "=", "_", "\\", "|", "~", "<", ">", "€", "£", "¥", "•"];
    if (src == " ") {
    1
    } else {
    for (i=0;i<lib.length;i++) {
    if (src == lib[i]) {
    2
    break
    } else if (src == lib[i].toUpperCase()) {
    3
    break
    } else {
    for (n=0;n<libNum.length;n++) {
    if (src == libNum[n]) {
    4
    break
    } else {
    for (s=0;s<libSym.length;s++) {
    if (src == libSym[s]) {
    5
    break
    This technically works, but I was wondering if there is a more efficient way to do this. This is quite slow as it requires nesting for loops within for loops.
    Michael Hunter replied 4 years, 2 months ago 3 Members · 3 Replies
  • Dan Ebberts
    July 14, 2022 at 8:26 pm
    If you’re using the JavaScript expression engine, you can improve things a lot by using array.includes():
    if (src == " ") {
    1;
    }else if (lib.includes(src)){
    2;
    }else if (lib.includes(src.toLowerCase())){
    3;
    }else if (libNum.includes(src)){
    4;
    }else if (libSym.includes(src)){
    5;
    }else{ // just in case
    6;
  • Edward Clayton
    July 14, 2022 at 9:10 pm
    Perfect, thank you!
  • Michael Hunter
    July 14, 2022 at 11:00 pm
    I like dan’s code. If distinct you can also create a strings a libraries and switch on charindex(input)
