check the difference between 2 sequences in Source/Record monitors
Hallo! I would be very grateful if someone tells me how can I check the difference between 2 sequences in Source/Record monitors. I have 2 sequences, which are almost same. I have to look for the difference. I have first sequence in source monitor, second sequence in Record monitors. What should i do, that both monitors running in parallel?
Thanks for the answer!
Irina
