Activity Forums Adobe Encore DVD Check Project???/ Button Hierearchy????
  • Check Project???/ Button Hierearchy????
    Posted by Joey Condeelis on April 24, 2008 at 11:54 am
    I am ready to burn a DVD and when I check Project I get this “Untitled Project” and then “Title Remote not set” What is it and how do I set it or fix it. DVD renders just fine anyway, just wanting to learn. THANKS
    ps I know how to “Rout Buttons” but I do NOT know how to rout or CHANGE the middle number on the routing display. How do I make or change the buttons Hierarchy?????
    THANKS!!!!!!!!!!!!!!
    THANKS
    Jeff Bellune replied 18 years, 4 months ago 2 Members · 3 Replies
  • Jeff Bellune
    April 24, 2008 at 12:53 pm
    Title Remote is set in the Properties panel for the Disc. It determines which menu gets activated when the Top Menu or Title Menu button is pressed on a DVD player’s remote control.
    Each menu button has a properties sheet in the Properties panel. Button number one is the default button. The default button is the one that is highlighted when the menu appears. Use the Properties panel to change button numbers.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Joey Condeelis
    April 24, 2008 at 4:05 pm
    THANKS Jeff!
    THANKS
  • Jeff Bellune
    April 24, 2008 at 4:20 pm
