Activity Forums Creative Community Conversations Check out the multicam videos
  • Jeremy Garchow
    February 1, 2012 at 2:09 pm
    [Herb Sevush] “When I shoot with multiple cameras I use the tracks of the various cameras as a multi-track audio source. All cameras get a mixed track on ch. 1, but I iso the various talent on each of the Ch.2 tracks on the different cameras, along with iso shotgun effects tracks. While I’m sure it’s easy to switch the video of a given clip between the various angles, how easy is it to witch the audio of a given clip between the various angles and between different channels, all while maintaining sync?”
    If every camera has the same ch1, then you would simply switch to what audio angle and video angle you’d need.
    Isn’t that what you do in 7 now?
  • Herb Sevush
    February 1, 2012 at 2:18 pm
    [Jeremy Garchow] “If every camera has the same ch1, then you would simply switch to what audio angle and video angle you’d need.
    Isn’t that what you do in 7 now?”
    Actually what I need to do is use some of the different Ch.2 iso’s to fix problems in the mixed track. With 7 there are a number of ways to do this, using either the audio from one of the angle’s of the multi-clip or actually matching back to the original source clip to get the audio.
    I’m watching Andy Neil’s MultiCam tutorials and I see that the multi-clip functions allow for switching audio between angles fairly easily, so it looks good so far, as long as I can isolate Ch.2 from Ch.1 when I need to, although I’ve heard this is one of the clunkier aspects of X.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
  • Jeremy Garchow
    February 1, 2012 at 2:32 pm
    [Herb Sevush] “Actually what I need to do is use some of the different Ch.2 iso’s to fix problems in the mixed track. With 7 there are a number of ways to do this, using either the audio from one of the angle’s of the multi-clip or actually matching back to the original source clip to get the audio.
    I’m watching Andy Neil’s MultiCam tutorials and I see that the multi-clip functions allow for switching audio between angles fairly easily, so it looks good so far, as long as I can isolate Ch.2 from Ch.1 when I need to, although I’ve heard this is one of the clunkier aspects of X.”
    That’s what I figured. If you’re going through and doing post switch audio work, you’ll be fine.
    I find choosing audio tracks in FCPX not to be clunky, but this is me you’re talking to.
    I’m sure you can match back to a clip, add the audio only and choose which audio track, or simply choose which audio track to use in the inspector before you add to the Project.
  • Herb Sevush
    February 1, 2012 at 2:41 pm
    [Jeremy Garchow] “I find choosing audio tracks in FCPX not to be clunky, but this is me you’re talking to.
    I had been led to believe that switching back and forth between different audio channels from the same source clip was awkward – that is going ch.1 / ch.2 / ch.1 audio from a single continuous clip.
    Well, I guess it will have to wait till I try it out and then I’m sure I’ll have lots or real questions to post.
    Herb Sevush
    Zebra Productions
  • Jeremy Garchow
    February 1, 2012 at 2:58 pm
    [Herb Sevush] “I had been led to believe that switching back and forth between different audio channels from the same source clip was awkward – that is going ch.1 / ch.2 / ch.1 audio from a single continuous clip. “
    If by switch you mean adjust the audio nodes, FCPX is amazing at this. You can select ranges on the fly and turn the levels up or down. You can have multiple audio tracks in the timeline just like seven and adjust levels between them just like seven. I know I’m a geek about this stuff, and everyone will make their own decisions, but I find X’s audio mixing to be pretty nice if you can embrace the tracklessness.
  • Herb Sevush
    February 1, 2012 at 3:34 pm
    Jeremy –
    under the heading of 1 pix and a lot of words let me present the following:
    The audio is in sync to the video clip. The middle audio section (highlighted) is ch.2, the host’s iso track, the left and right audio sections are from ch.1, the mixed track. The reason for the edit was clothing rustle on the talents mic which ruined the mixed track. Is this sort of thing easy to do in X?
    Herb Sevush
    Zebra Productions
  • Tomas Rugevicius rugys
    February 1, 2012 at 8:42 pm
    Hi all.
    I found no way to access separate audio channels on multiclip on the timeline. There is no way of detaching them in timeline as you usually do with simple clips if you want to work with separate channels.
    You can only turn of/on a right or left mono channel on original clips engaged in multiclip.
    Or I am missing something, or Apple is.
  • Herb Sevush
    February 1, 2012 at 8:48 pm
    [Tomas Rugevicius Rugys] “I found no way to access separate audio channels on multiclip on the timeline. There is no way of detaching them in timeline as you usually do with simple clips if you want to work with separate channels. You can only turn of/on a right or left mono channel on original clips engaged in multiclip”
    Well that’s not welcome news, is it. I guess someone will come up with a work around.
    That’s the problem with using demo’s based on music videos – they’re actually very easy to cut and don’t have the required complexity to test a multi-cam function properly.
    Herb Sevush
    Zebra Productions
  • Jeremy Garchow
    February 1, 2012 at 11:39 pm
    Herb-
    First of all, is that America’s Test Kitchen??? Cool.
    Second, thanks for the picture.
    In your case, I’d lay channel 1 as angle. Then use the rest of the angles as separate mono tracks as needed.
    You can then blade where you want, and change the audio angle on that section like you have shown.
  • Herb Sevush
    February 2, 2012 at 2:30 am
    [Jeremy Garchow] “First of all, is that America’s Test Kitchen??? Cool.”
    Yes its ATK. I hepled develop it 12 years ago and have been Dir/Editor ever since.
    [Jeremy Garchow] “In your case, I’d lay channel 1 as angle. Then use the rest of the angles as separate mono tracks as needed. You can then blade where you want, and change the audio angle on that section like you have shown.”
    For next year I can change the audio assignments so everything I want is always on Ch.1 of the various angles. it would be nice to be able to cut back and forth between Ch.1 and Ch.2, but it’s not a deal breaker as long as I can specify how the material is shot.
    Herb Sevush
    Zebra Productions
Page 2 of 2
