Activity Forums Adobe After Effects Expressions Check if Variable is equal to one of multiple values. (ex : 1 OR 4)
  • Check if Variable is equal to one of multiple values. (ex : 1 OR 4)
    Posted by Lucas Piazzini on August 13, 2022 at 5:35 pm
    Hello ! I have a menu and need my expression to check if its value is, for example, 1 OR 4 OR 7.
    Unfortunately, none of the methods I’ve seen online work, which are :
    if(menu == 1|| 4 || 7)
    and
    var array = [1,4,7];
    if(array.includes(menu))
    None of these give me a true result when menu is equal to one of them, all I have are false returns. Do you have any ideas?
    Sincerely, Lucas
    Lucas Piazzini replied 4 years ago 2 Members · 2 Replies
  • Paul Conigliaro
    August 13, 2022 at 6:11 pm
    The syntax for multiple OR conditions would need to be something like:
    if(menu==1 || menu==4 || menu==7)
    Your idea of using includes() is spot on. But you might have to add .value to your variable if it’s pointing to a control like a menu. So it might looks something like:
    let arr = [1,4,7];
    arr.includes(menu.value);
  • Lucas Piazzini
    August 13, 2022 at 7:16 pm
    Oooh indeed, it works ! Thank you so much!
