Activity Forums Adobe After Effects Expressions Check Box Expression: if one box is checked, the rest are automatically unchecked or disabled
  • Check Box Expression: if one box is checked, the rest are automatically unchecked or disabled
    Posted by Elizabeth Starr on May 13, 2020 at 5:32 pm
    I have 5 layers that can each be turned on with a checkbox. Problem is, I need only one box to be able to be checked at a time. Currently, you can check all 5 boxes, resulting in something not so desirable. How can I Iimit one check box checkable at a time?
    Thanks in advance for your help!!!! 🙂
    lay1 = thisComp.layer("INSTAGRAM").effect("Checkbox Control")("Checkbox");
    lay2 = thisComp.layer("TWITTER").effect("Checkbox Control")("Checkbox");
    lay3= thisComp.layer("FACEBOOK").effect("Checkbox Control")("Checkbox");
    lay4= thisComp.layer("YOUTUBE").effect("Checkbox Control")("Checkbox");
    lay5= thisComp.layer("SKYPE").effect("Checkbox Control")("Checkbox");
    lay6= thisComp.layer("SNAPCHAT").effect("Checkbox Control")("Checkbox");
    y=transform.position[1];
    if
    (lay1==1 || lay2==1 || lay3==1|| lay4==1|| lay5==1|| lay6==1)
    x= 630.5;
    else
    x= 572.5;
    [x,y];
    Elizabeth Starr replied 6 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    May 13, 2020 at 5:37 pm
    In my experience, attempting to simulate radio button behavior with checkboxes is doomed to failure. It may seem like it works, but there are subtle order-of-operation dependencies that will make it unreliable. Can’t you use a dropdown menu instead?
    Dan
  • Elizabeth Starr
    May 13, 2020 at 5:56 pm
    Sure! How would I rewrite the expression using a dropdown menu?
  • Dan Ebberts
    May 13, 2020 at 6:35 pm
    It depends on how you have things set up, but I guess I’d add a dropdown menu control to a layer named “Controls”, add 3 additional elements to the control and name them to match your previous expression:
    INSTAGRAM
    TWITTER
    FACEBOOK
    YOUTUBE
    SKYPE
    SNAPCHAT
    Then add an expression like this to each of your logo layers (this example would be for the FACEBOOK layer (#3 in the list):
    id = thisComp.layer(“Controls”).effect(“Dropdown Menu Control”)(“Menu”).value;
    x = id == 3 ? 630.5 : 572.5; // this is where you specify the id that corresponds to this layer
    [x,value[1]]
    Something like that…
    Dan
  • Elizabeth Starr
    May 15, 2020 at 11:44 pm
    Thanks so much, Dan.
