Activity Forums Adobe After Effects Expressions Check a render queue item exists or alert
  • Check a render queue item exists or alert
    Posted by John Wilkins on April 4, 2008 at 5:15 pm
    I’m using the following statement in a script to display the filename of the (1) render queue output file.
    var outputPath=app.project.renderQueue.item(1).outputModules[1].file.name.replace(/%20/g, “_”);
    output = app.project.activeItem.layers.addText(outputPath);
    Currently if the render queue item does not exist you get a script error – I would like to include a condition in the script which checks to see if the item exists and produces an alert if it doesn’t but am unsure as how to approach it.
    Any advice or direction would be greatly appreciated
    John
    John Wilkins replied 18 years, 5 months ago 3 Members · 5 Replies
  • Filip Vandueren
    April 4, 2008 at 6:05 pm
    You could perhaps check for
    app.project.renderQueue.numItems>0
  • Dan Ebberts
    April 4, 2008 at 6:06 pm
    Have you tried using renderQueue.numItems ?
    Dan
  • John Wilkins
    April 4, 2008 at 11:10 pm
    Thanks guys, I’ve tried this but the problem is I’m still pretty new when it comes to the actual scripting syntax so i’m not 100% how to implement it. This is what I currently have:
    if(app.project.renderQueue.numItems>0)
    alert(‘Add an output file!’);
    else
    output.name = ““;
    output.transform.position.setValue([25,450]);
    However, it doesn’t seem to be functioning correctly and I still just get the same error as before.
    Any pointers would be great!
    John
  • Dan Ebberts
    April 5, 2008 at 12:51 am
    You just need to rearrange things a little:
    output.name = “”;
    else
    Dan
  • John Wilkins
    April 5, 2008 at 12:44 pm
    Thanks very much Dan. That works perfectly.
    I’m very new to ae scripting so sometimes the syntax gets away from me. I’ve downloaded the AE Scripting Guide and now the ECMAScript Language Specification so hopefully these will help.
    Thanks again
    John
