Activity Forums Apple Final Cut Pro Legacy Cheapest Storage Solution
  • Cheapest Storage Solution
    Posted by Joseph Wilkins on October 23, 2006 at 10:49 pm
    I want to spend a grand or so on the most cost effective way of backing up P2 footage I shoot on my DVX200 – what is the best value per gig solution out there for under a grand?
    thanks
    Lu Nelson replied 19 years, 11 months ago 6 Members · 5 Replies
  • David Roth weiss
    October 23, 2006 at 10:57 pm
    Joseph,
    Wonderful 500gb drives are available for under $200 and firewire enclosures can be had for $25 to $80 dollars. Thats the cheapest solution, but there are better solutions. Do you want to spend the entire $1000 or would $300 do it for you? Check out http://www.newegg.com and whip out your credit card.
    DRW
  • Shane Ross
    October 23, 2006 at 10:58 pm
    Get internal SATA drives. 250GB for under $100…typically around $65-$90. Then get one firewire case (empty) and swap out the drives, or an adaptor cable like this one to connect it to your drives:
    https://www.geeks.com/details.asp?invtid=2020&cpc=SCH
    Then when you back up the footage, wrap the drives in their plastic and put them on the shelf. That is what I did.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mark Raudonis
    October 24, 2006 at 3:02 am
    Don’t know where you live, but out here in Los Angeles, there’s a computer superstore called “Fry’s”. They had 750 gig SATA drives (Seagate) on sale last week for about $300 bucks! That’s approximately $2.50per gig. Don’t know if you can get any cheaper than that.
    I lapped up a handful and threw them into our on-line g-5’s for saving backups.
    Mark
  • Ernie Santella
    October 24, 2006 at 3:17 am
    Try this…
    I just installed 3 Maxtor 300GB SATA 3GB drives in my new MacPro. 900GB of 3GB speed SATA for under $300!
    https://www.pagecomputers.com/store/product.asp?catalog%5Fname=Storage+Devices&category%5Fname=29g29c565s2283&product%5Fid=973306
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Lu Nelson
    October 24, 2006 at 7:24 am
    If this is to be your backup solution for material you’ve shot and you have no other backup i.e. tape, you should consider a RAID 1 setup. You can buy dual drive enclosures from otherworldcomputing that go up to 750GB in mirrored format (two drives in one enclosure, each with identical data). They sell them in a RAID 1 version, with a copy of SoftRAID which is the best software for doing mirrors (better than OSX). This will give you some security against one drive failing, and SoftRAID will warn you of any errors at any point
    look here:
    https://eshop.macsales.com/shop/firewire/1394/USB/EliteAL/MirrorRAID/
