  • Posted by Richard Ragon on August 10, 2005 at 8:41 am
    After months of screwing around with Adobe Premiere Pro, one of the companies that I work with is finaly bitting the bullet, and going FCP.
    They use BetaSP decks, and have a BlackMagicSP capture card in the PC, which they intend to use for the new G5.
    However, they also have a non Mac compatiable Raid system, and will have to purchase a Mac compatiable RAID setup.
    Whats the cheapest, easiest way to get a 4+ drive RAID setup?
    firewire,fiber?
    -Richard
    Shane Ross replied 21 years, 1 month ago 3 Members · 4 Replies
  • Shane Ross
    August 10, 2005 at 9:54 am
    Define cheap…for about $1200 you can get 1TB with the following:
    G-Raid. FW 800 and can handle 8-bit and even 10-bit uncompressed (www.bhphoto.com).
    ALSO, look at the FirmTek External SATA Raids (https://store.yahoo.com/firmtek/)
  • Richard Ragon
    August 10, 2005 at 4:26 pm
    Cheap.. as in. 3-4 Drives (perfer SATA’s) linked in one enclosure, using RAID to where they will work with BetaSP full uncompressed settings.
    -Richard
  • Bob Vick
    August 10, 2005 at 5:05 pm
    Cheap is okay as long dependable isn’t sacrificed. Uncompressed Beta SP, 10 bit is demanding. SCSI is dependable, faster than firewire and not as costly as Fibre.
    b
    Bob Vick sr promo guy @ ch3 wwmt tv, kalamazoo, mi
  • Shane Ross
    August 11, 2005 at 4:39 am
    The Firmtek SATA will do you fine, as would a G-SATA…even a G-RAID FW800 can handle 4 streams of 8-bit and 2 streams of 10-bit uncompressed. G-Raid 500 is $549 at http://www.bhphoto.com. G-SATA is $150 more for the same space, but has better transfer speed.
