Activity › Forums › Lighting Design › cheap on-camera light
  • cheap on-camera light
    Posted by Bob Cole on August 18, 2009 at 2:42 am
    I will soon be doing a lot of run-and-gun shooting with an HDV camera which lacks the PowerTap. My sop is to power my Anton Bauer Ultralight2 from a fanny pack loaded with an AB brick and a gold mount, but I’d prefer a lighter, less tethered alternative.
    Do you know of a cheap but effective on-camera light, possibly LED, and preferably powered by AA’s or the same HDV camera batteries that my Sony Z1 uses?
    Thank you!
    Bob C
    P.S. If it only lasts a year, that’s fine. I’m planning to add some frost to the front of it so it doesn’t even need to have a very even light pattern.
    Bob Cole replied 17 years ago 4 Members · 8 Replies
  • 8 Replies
  • Michael Palmer
    August 18, 2009 at 2:49 am
    https://www.flolight.com/microbeam-128.html
    I have 3-LED 500’s from these guys and they are great. I’m going to order the larger unit.
    https://www.flolight.com/led-lighting/microbeam-256.html
    Good Luck
    Michael Palmer
  • Jason Jenkins
    August 18, 2009 at 3:55 am
    [Michael Palmer] “https://www.flolight.com/microbeam-128.html
    https://www.flolight.com/led-lighting/microbeam-256.html“
    These look like they might actually be useful, unlike the microlight.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Bob Cole
    August 18, 2009 at 3:58 am
    These look very nice. Thank you for the tip.
  • Michael Palmer
    August 18, 2009 at 1:52 pm
    What is nice is the dimmer control and it looks like a solid unit unlike the micro lite.
    Good Luck
    Michael Palmer
  • Bob Cole
    August 18, 2009 at 9:40 pm
    What about the dreaded green spike? If you put on the minus-green filter, and the tungsten filter, you aren’t going to have much light left. Although I prefer the smaller size of the 128, I’m thinking of the 256.
    Bob C
  • Michael Palmer
    August 18, 2009 at 10:37 pm
    the 128 is much bigger than the competition and should supply you with plenty of lumens, I purchased the Micro Lite and wished I hadn’t.
    Good Luck
    Michael Palmer
  • Jb Letchinger
    August 23, 2009 at 5:20 am
    I’ve used lights like this on HDV cameras, and with some diffusion, they’re OK for what they are… and yes, cheap… – check carefully for battery compatability…
    Sony HVL-20DW2
    https://www.bhphotovideo.com/c/product/162282-REG/Sony_HVL20DW2_HVL_20DW2_20_watt_Video_Light.html
    JB
    JBL Films, Inc.
    please vist
    https://www.jblfilms.com
    https://www.jblfilmsinc.com
  • Bob Cole
    September 29, 2009 at 5:28 pm
    Thanks for the tip. I have had my first shoots with the FloLight 128, and it worked well. It’s a nice amount of light, not terribly large, & runs a long time on a battery. I wouldn’t want to use the bigger lights on a camera, at least not for run-and-gun.
    I used a minusgreen, frost, and CTO filters (provided), and got a very pleasing quality of light on faces. Although there is a little slot for them, the filters’ flexibility will allow them to fall out, so you do need to secure them with tape.
    The ball socket mount can be a bit tough to tighten up enough to keep the light pointed correctly. The height the mount provides makes it seem a bit unwieldy, but at the same time, it’s good to have the light that much higher than the lens, for the subjects with eyeglasses.
    Very good recommendation – I appreciate it, Michael.
    Bob C
