Activity › Forums › Apple Final Cut Pro Legacy › Cheap analog capture card for FCP7.
  • Shane Ross
    January 26, 2014 at 6:48 pm
    [Karel Voners] “PCI-X or PCI-E, doesn’t matter I think.”
    It does matter. This is pretty important. These are different connections. Are you running a G5, or a MacPro?
    This card is cheaper than both the ones listed, and does what you need:
    https://www.blackmagicdesign.com/products/intensity
    Although ProRes HQ for VHS? that’s overkill. The quality won’t improve at all over ProREs 422. Only increase you’ll see is file size.
    Shane
    Little Frog Post
  • Karel Voners
    January 26, 2014 at 7:05 pm
    I’m running hackintosh so I got PCI but no PCI-X. So it does matter like you say.
    But the newer blackmagic solutions start at 200$, much more then the 90$ Blackmagic Decklink on ebay…
    https://www.benl.ebay.be/itm/111261595124?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    Or am I missing something?
    Cheers!
    K.
  • Shane Ross
    January 26, 2014 at 11:52 pm
    PCI? Not PCI-X nor PCIe?
    Shane
    Little Frog Post
  • Steve Eisen
    January 27, 2014 at 2:22 am
    [Karel Voners] “I’m running hackintosh”
    Your gonna need a hackincard. I’ve never seen one.
    If your computer has firewire, you can use a dv camcorder to capture to DV format.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Shane Ross
    January 27, 2014 at 2:57 am
    Not really. My friend has a Hackintosh running a Decklink Extreme. Cut a doc feature with it.
    Shane
    Little Frog Post
