Activity Forums DaVinci Resolve Chase Audio Sync Slipping
  • Chase Audio Sync Slipping
    Posted by Tony Manolikakis on January 2, 2014 at 4:12 pm
    Just upgraded to Davinci 10.0.2. Working in a 23.976 fps timeline. Chase audio extracted from reference movie. The audio seems to slip out of sync over duration of the timeline. Feels like the audio is playing back at 24 fps and not 23.976. Projects were imported from DaVinci 9.x.
    Any thoughts.
    Tony Manolikakis
    Rev13 Films
    Tony Manolikakis
    Rev13 Films
    Tony Manolikakis replied 12 years, 8 months ago 2 Members · 2 Replies
  • Jake Blackstone
    January 2, 2014 at 10:04 pm
    I have seen it happens many times, when I use XML from Premiere. As I verify my conform, the video, not audio would slip a frame every 30: or so. If I leave it as is, on the roundtrip, the video would line up back in Premiere perfectly, but if I try to fix the slippage in resolve, back in Premiere it would then be slipped the wrong way (one frame too short). So, I just adjust the offset by a frame in resolve to get the offline to agree with conform. It sure looks like 23.98 vs 24.
  • Tony Manolikakis
    January 3, 2014 at 4:47 am
    Everything was in sync before moving to DaVinci 10. Also, it’s just the chase audio that is out of sync. As a test, I conformed the reference movie to true 24fps then extracted the audio from it and used that audio as the chase audio. Audio stays in sync now. So it appears to be some sort of bug with monitoring at 23.976 and chase audio.
    Tony
    Tony Manolikakis
    Rev13 Films
