Activity › Forums › VEGAS Pro › Chart for rendering settings
  • Chart for rendering settings
    Posted by Linda O’connell on November 6, 2017 at 2:35 pm
    For the past 10 years I have been using a chart that shows what settings to use when making a DVD based upon length of the project.
    I have had it sitting here and now it has disappeared!
    Does anyone know where I can get a copy?
    Francois Pénzes replied 8 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    November 6, 2017 at 3:06 pm
    [Linda O'Connell] “Does anyone know where I can get a copy?”
    I don’t remember seeing it, but was it John Meyers DVD chart? I’ve had a trawl of the Vegas forums and can’t find it. I’ve been using Marks Bitrate calculator which is real-time calculator that’s held me in good stead over the years.
    * Grazie
  • Jorma Nippala
    November 6, 2017 at 3:16 pm
    Yes, it seems John Meyer’s chart links there do not open any more, but here’s “Mark’s DVD BitRate Calculator” https://www.johncline.com/bitcalc110.zip
  • Linda O’connell
    November 6, 2017 at 4:16 pm
    Yes, I believe it was John’s chart. But I can make the other work. Thank you!
  • Graham Bernard
    November 6, 2017 at 4:33 pm
    [Linda O'Connell] “But I can make the other work.”
    Sure. It’s very easy to get results and the tweaking is superb. Having done some further research, Johns chart may have been a Spreadsheet? Yes?
    * Grazie
  • Francois Pénzes
    November 7, 2017 at 2:33 am
    Hi Jorma
    Do you still have the old or broken link(s) ?
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
  • Jorma Nippala
    November 7, 2017 at 11:20 am
    Francois, the links are in old SCS forum threads archived on https://forum-archive.magix.info/home. Searching there (Words) calculator and (User) johnmeyer returns 100+ threads starting from 2003 (https://www.vegascreativesoftware.info/us/forum/help-on-mpeg-2-encoding-to-dvda–15972/).
    Many later threads also with the same link and another link from 2011 https://www.vegascreativesoftware.info/us/forum/dvd-capacity-vs-bitrate-calculator–87421/. There may be a couple others, but none of them worked or gave the right file (the spreadsheet Graham mentioned) even trying with Wayback Machine.
  • Francois Pénzes
    November 8, 2017 at 10:39 am
    Hi Jorma
    Thx Jorma ! To bad some good stuff gets deleted.
    Found this link. Maybe it’ll help.
    https://www.sonyvegas.co.uk/rendering-tips-for-dvd-a-by-john-meyer/
    Cheers !
  • Jorma Nippala
    November 8, 2017 at 1:36 pm
    Francois, both calculators linked there are often recommended, in fact the second one was mentioned earlier in this thread. I don’t think the page mentions the johnmeyer Excel spreadsheet calculator. A “quick and dirty” table is in his post here. You can compare that with a larger table from jetdv.com/.
    While we’re at it, there’s an old (still working) spreadsheet calculator link here. I didn’t try it.
  • Francois Pénzes
    November 9, 2017 at 1:22 am
    Thx Jorma !
    Cheers !
