Activity › Forums › Adobe After Effects › Charles Swabb Commercial
Posted by Brian Tetamore on April 3, 2007 at 1:18 amAnyone know what filter effect they used to create the newest commercial? It’s called “Talk to Chuck” and features a simple headshot of a guy talking to the camera while working out in a gym. I believe the effect is similar to the “cutout” filter in Photoshop.
Curious, thanks
The Visual Rabbi
Sean Siegler replied 19 years, 5 months ago 5 Members · 4 Replies -
Steven J casey
April 3, 2007 at 2:19 amDo a search on cartoon effect. There’s been tons of questions and lots of methods suggested for getting the effect.
Steven
Mike Procunier
April 3, 2007 at 4:07 pmThey use proprietary software created by Bob Sabiston called “Rotoshop”. He also used it for the movies “Waking Life” & “A Scanner Darkly”. It’s not available to the public. Read about it here: https://www.flatblackfilms.com/
If you want to recreate something similar using Illustrator & After Effects I believe Aharon Rabinowitz did a tutorial here on the cow about 6 months ago.
I just did a quick & dirty for a recent project. Apply “Posterize” or “Reduce Colour”(Pete’s Plugins)to your footage. Duplicate layer. Add “Find Edges” , “Hue/Saturation”(set Saturation to -100) & “Fast Blur” (Blur= 1 pixel) to the top layer. Change the top layers tranfer mode to “Darken”. Ta da. Kind of Cartoony, not as clean as Charles Schwab but it took you 3 minutes. This effect works best on footage where the subject is in front of a fairly clean background. To tweak the black lines add a “levels” effect and really crush the mids and whites. -
Paul Hamrick
April 5, 2007 at 8:58 amAnother way is to grab a frame of your video and take it into Photoshop. In PS play with the filters to get the look you want, after you have it down, create an action. (don’t save the frame – save the action).
Now in AE export your footage as an image sequence – then batch process the sequence using the PS action that you created. Import the footage back into AE and then render as a movie.
Sean Siegler
April 5, 2007 at 10:28 amIf you are on a Mac you could also try using the software “Studio Artist”.
It is pretty powerful and almost infinitely flexible in terms of customizing the look you want.
https://www.synthetik.com/
