Activity Forums Panasonic Cameras charging batteries
  • charging batteries
    Posted by Colin Thomas on February 8, 2006 at 5:38 pm
    I just wanted to double check something regarding rechargeable batteries. Lithium Ion batteries do not need to be fully discharged before recharging, correct? I ask because I’m concerned that I’m not getting the full run time out of my batteries that I should. But, this may be due to the fact that I am mostly shooting in cold weather conditions.
    Thanks for the confirmation.
    Rafi Bagramian replied 19 years, 10 months ago 3 Members · 3 Replies
  • Noah Kadner
    February 8, 2006 at 6:12 pm
    That’s correct on both accounts. They do not need to be fully discharged before recharging and they will often have shorter life in extreme climates. If you want longer lasting batteries, I highly recommend these bad boys:
    https://www.dvxuser.com/articles/battery/
    -Noah
  • Rafi Bagramian
    November 1, 2006 at 9:27 pm
    The Catalog says: “Store the Battery only when it is fully discharged.” !!!!!!!!!
  • Rafi Bagramian
    None
