Activity Forums Maxon Cinema 4D Character tab Missing
  • Character tab Missing
    Posted by Soham Jani on March 30, 2016 at 9:36 pm
    My character tab is missing, and I can’t rig my character. help?
    \”It\’s all around us Neo, temporary constructs of time…..\”
    Jim Scott replied 10 years, 4 months ago 2 Members · 3 Replies
  • Jim Scott
    March 31, 2016 at 3:31 pm
    Go to the Layout selector and choose “Cinema 4D Menu” in the bottom section. This should give you the full set of menus.
  • Jim Scott
    March 31, 2016 at 11:19 pm
    And if that doesn’t work:
    Go to Window>Customization>Customize menus. A “menus” window will open up, where you can customize your menus and submenus. Select M_EDITOR if it’s not already selected and look at the list. If Submenu Character is missing I think you may have removed it by accident or have a corrupted prefs file… in which case quit C4D and look in your Maxon>Cinema 4D Rxx >prefs folder, and if there is a c4d_M_EDITOR.res file remove it and restart Cinema. That should force it to revert to the default menu with all of its submenus.
    Hope this helps.
  • Jim Scott
    April 6, 2016 at 4:12 pm
    It would be nice to know if my suggestion worked or if you found another solution.
