Activity Forums Maxon Cinema 4D character rigging question – no mesh possible?
  • Cactus Dan
    September 13, 2009 at 12:11 pm
    Howdy,
    Make Editable is the command to use (under the Functions menu) to convert geometric primitives and nurbs objects into editable meshes. It will also make spline primitives into editable splines.
    You only need to use mesh objects if the objects will deform or bend. Rigid characters, made up of several different parts (like robots and such) which will not deform, don’t need to be mesh objects. You can simply rig the parts themselves by constraining them or parenting them to a rigged joint skeleton.
    Adios,
    Cactus Dan
    Cinema 4D R10 XL Bundle, BodyPaint, Dynamics
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
  • Dave Glanz
    September 13, 2009 at 2:19 pm
    Thanks Dan – what would be the best way to create a skeleton and rig it to a non-mesh object?
    https://www.daveglanzproductions.com
  • Cactus Dan
    September 15, 2009 at 5:18 pm
    Howdy,
    Well, the easiest way is to parent the objects to the joints, but you want make sure to place them as secondary children of the joints like this:
    +Joint
    +-Joint
    +–Joint
    +—Object
    +–Object
    +-Object
    … otherwise the objects would interfere with the joints’ rigging.
    Adios,
    Cactus Dan
