Activity Forums Maxon Cinema 4D character rigging
  • character rigging
    Posted by Mouhamad Ali darwich on September 1, 2011 at 9:48 pm
    hello everybody
    I’m trying to learn character rigging .. but I stopped at a point that is when I try to add a constaint to the hand joint and add the arm’s control null that contain the ik .. the when I try to rotate this null the hand starts to move as it’s vibrating not rotating :S .. I think the problem is in freezing the coordinates but not sure .. and if this is the problem when should I freeze them?
    thanks in advance 🙂
    Cactus Dan replied 14 years, 11 months ago 2 Members · 1 Reply
  • Cactus Dan
    September 11, 2011 at 12:42 pm
    Howdy,
    When it comes to problems with rigging, it’s always best to post your file so someone can take a look. Rigging can get quite complicated and you could have other issues that are actually causing the problems.
    Adios,
    Cactus Dan
    Cinema 4D R10 XL Bundle, BodyPaint, Dynamics
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
