Activity Forums Adobe After Effects Expressions Character count and Frames
  • Character count and Frames
    Posted by Criis Daw on May 23, 2013 at 10:20 am
    Hi there…
    I am animating the text on using a range selector. I am making it so the text reveals at 1 character per frame.
    Using this “thisComp.layer(“text”).text.sourceText.length”
    I am able to count the characters and put the key frames a corresponding distance apart ..
    but what I would really like to do is have the character count (excluding spaces (it animates nicer that way) ) be used to drive an expression .. rather than just telling me.
    So it would be . ,, Take the charactrs count (excluding spaces) and finish the animation on the range selector this number of frames up the time line.
    Am I explaining this very well ??
    Hope so ..
    Chris
    Eliezer Cisner replied 12 years, 8 months ago 3 Members · 12 Replies
  • 12 Replies
  • Dan Ebberts
    May 23, 2013 at 1:30 pm
    I’d use an expression selector with an amount expression like this:
    if (timeToFrames(time-inPoint) > textIndex) 0 else 100
    Dan
  • Criis Daw
    May 23, 2013 at 1:45 pm
    Hummm
    not sure I understand
    what is an expression selector ?
  • Criis Daw
    May 23, 2013 at 4:20 pm
    ha ha
    google is my friend …
    thanks for the help and i’ll be back 🙂
  • Criis Daw
    May 23, 2013 at 11:50 pm
    Ha ha
    you beauty .. Never even seen expression selectors hidden way down there. ….
    brilliant , thanks very much
  • Criis Daw
    May 23, 2013 at 11:54 pm
    How would I make it so the characters come in every 2 frames for example ?
    I have them coming in at ten frames now but am just experimenting with it.
    Its very cool
  • Dan Ebberts
    May 24, 2013 at 12:01 am
    if (Math.floor(timeToFrames(time-inPoint)/2) > textIndex) 0 else 100
    Dan
  • Criis Daw
    May 24, 2013 at 12:10 am
    blimey…
    now you are just confusing me …
    One last thing .. Now I have my text writing on simply , beautifully and repeatable with little effort ..
    Using range selectors and duplicate layer above with the blending made set to add i am able to make the leading letters write on with a glow..
    As the range selector write the other writes off so the first character only is displayed giving a pleaseing glow to the lead character…
    I have tried to do it by manipulating what you sent but succeeded in writing off .. not on..
    Any more tip s ??
  • Eliezer Cisner
    January 20, 2014 at 9:30 pm
    How can I make this expression ease out?
  • Dan Ebberts
    January 20, 2014 at 10:41 pm
    I think something like this would work:
    framesPerChar = 3; // frames per character
    t = time – inPoint;
    tStart = framesToTime(framesPerChar)*(textIndex-1);
    tEnd = framesToTime(framesPerChar)*textIndex;
    ease(t,tStart,tEnd,100,0)
    Dan
  • Eliezer Cisner
    January 20, 2014 at 10:45 pm
    Hmm, doesn’t seem to work. It still goes one character per frames (set it as that) even as it’s approaching the end.
