Activity Forums Adobe InDesign Chapters are all numbered “1” – how to fix?
  • Chapters are all numbered “1” – how to fix?
    Posted by Andrew Taylor on August 4, 2010 at 5:43 pm
    Hi – new user here. I’ve been exploring InDesign CS5 for a few weeks now, and I’m starting to understand how it works. However, I’m having what I’m sure is a simple issue that I need some help with.
    I’ve got a master page set up, and on that MP is a text frame in which I’ve done the Type>Text Variables>Insert Variable>Chapter Marker routine. A “1” immediately appears in the text frame.
    I’ve used this document to create a dozen other documents, with the intent of pulling them all into a book. The book numbers the pages correctly from chapter to chapter, but every chapter is numbered “1.”
    What have I done wrong here? What’s the best way to go about fixing it so the chapters are numbered consecutively?
    Thanks in advance for your help.
    Erica Gamet replied 16 years ago 2 Members · 1 Reply
  • Erica Gamet
    August 26, 2010 at 4:16 pm
    Do you have your chapters labeled in the Numbering & Section Options part of the Pages panel? If so, I don’t use text variables there…I name each chapter in the numbering sections and use Type > Insert Special Characters > Markers > Section Marker. Not sure if that helps or not…
    Erica Gamet
    Digital Dimensions
    https://www.digi-wizard.com/learn
    “…for there is nothing either good or bad, but thinking makes it so.”
