Activity Forums Apple Final Cut Pro Legacy chapter marks in FCP came out late
  • chapter marks in FCP came out late
    Posted by Katie Cooper on January 16, 2007 at 5:08 pm
    when i inserted chapter marks in my edit in FCP, and i watched the exported movie on DVD, and tested skipping from chapter to chapter, the chapters marks came out late each time. Do you have to set them early to compensate for this?
    thanks!
    Rafael Amador replied 19 years, 8 months ago 3 Members · 2 Replies
  • Chris Borjis
    January 16, 2007 at 6:32 pm
    there are chapter markers and another type of marker.
    I think you want the other type of marker (compression marker i think), as it will force an i-frame in
    the encoding process and be right where you want it
  • Rafael Amador
    January 17, 2007 at 8:18 am
    Yes what Borjis says is right. Maybe putting the chapter marker together with a compresion marker. Anyway it suposed that FC set a compression marker in any of the cuts and transition when you export to Compressor from the time-line.
    Salud,
    Rafael
