Activity Forums Apple Final Cut Pro Chapter Markers?
  • Chapter Markers?
    Posted by Greg Ball on November 22, 2019 at 4:52 pm
    Hi All
    Happy Friday! I have a series of 25 90-minute videos edited in FCPX. The client is asking for DVDs to be authored. Each DVD will have about 20-30 chapters.
    They’ve indicated where each chapter will be using time codes.
    I’m having an outside author these DVDs. They use Encore for authoring. (They edit on Premier)
    My question is If I add Chapter markers in FCPX and export ProRes 422 files, will these markers work within Encore? Is FCPX compatible with Encore?
    Thanks.
    Greg Ball, President
    Ball Media Innovations, Inc.
    https://www.ballmediainnovations.com
    Eric Santiago replied 6 years, 10 months ago 4 Members · 4 Replies
  • Eric Santiago
    November 22, 2019 at 4:57 pm
    I do believe if you export a QT using Compressor with chapter markers intact, that will transfer over if imported into Premiere.
    But that was years ago so of late I have no idea.
    I can check in the next few hours.
  • Steve Connor
    November 22, 2019 at 6:36 pm
    I never made it work in Encore but I might have been doing something wrong!
  • Mark Suszko
    November 22, 2019 at 8:53 pm
    Would an XML file of the edit carry over the markers?
  • Eric Santiago
    November 22, 2019 at 9:03 pm
    I found some time to test this with recent software.
    From FCPX 10.4.3 to QT/FCPXML (used Xto7) then Premiere Pro CC2019, I can see the markers.
    I then tried ProRes/MPG to Encore and nothing works.
    I am not sure when they broke this but I was able to do this in the past.
    Its been so long since I’ve done any media with Chapter Markers.
