Activity Forums Adobe Encore DVD Chapter Markers not appearing
  • Chapter Markers not appearing
    Posted by Mark Whittle on January 7, 2010 at 1:52 am
    I have created a timeline in Premiere with Encore chapter markers, then sent to Encore CS4 via dynamic link. The chapter markers do not appear. This usually works fine. I have tried deleting the encore project and starting again but no joy.
    I have read other posts with similar issues but their suggestions haven’t worked. I am beginning to think CS4 has a lot of issues that need fixing. My old CS2 was very reliable but Encore CS4 (Mac version) crashes a lot on my new Mac Pro.
    I just created a new sequence in the same Premiere project and placed a few chapter markers, then sent this to Encore. The markers appear! huh?
    What is wrong with the original sequence?
    Mark W.
    Larry Zapotocky replied 15 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Jeff Bellune
    January 7, 2010 at 3:51 am
    Did you give each chapter marker a name in the original sequence?
    Are you sure you used Encore Chapter Markers and not ordinary Sequence Markers in the original sequence?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Mark Whittle
    January 11, 2010 at 2:08 pm
    Yes I have names on all chapter markers, and yes, they are all Encore markers.
    I have the same problem with another project with over 20 chapters. I just tried exporting a short segment as an MPEG2 file to see if the chapter data works that way, but no luck.
    Mark W.
  • Jeff Bellune
    January 11, 2010 at 2:31 pm
    Try your MPEG2-DVD export again with the following settings:
    Preferences:
    Export Settings:
    -Jeff
  • Mark Whittle
    January 18, 2010 at 2:24 am
    Thanks Jeff. Both of those settings were selected already.
    Is there a prefs file or two I can delete to see if that helps?
    Mark W.
  • Jeff Bellune
    January 18, 2010 at 8:27 am
  • Mark Whittle
    January 20, 2010 at 4:19 am
    Thanks Jeff. I went to the path user/documents/Adobe etc but there is no folder for Encore in there.
    Cheers.
    Mark W.
  • Jeff Bellune
    January 20, 2010 at 12:30 pm
    Unfortunately, I can’t help you find where files are on a Mac. I’m on a PC.
    -Jeff
  • Larry Zapotocky
    July 23, 2011 at 11:17 pm
    Same Problem! If I only put a couple chapter markers it works. I have about 30 on the one sequence and it only shows one when I import into encore.
    the only way I get it to work is to create a new sequence and copy and paste the entire timeline and then recreate the chapter marks. Works every time, but it is very frustrating.
    Any fixex yet?
    Larry Zapotocky
