Activity Forums VEGAS Pro Chapter markers from Vegas6 to DVDA3
  • Chapter markers from Vegas6 to DVDA3
    Posted by Wade Harrington on April 29, 2005 at 4:08 am
    I made a file and spent 30 minutes putting markers and naming them in Vegas 6. Rendered the file to DVDA template brought it into DVDA3 (after a 10 hour render) and there was no chapters in the file?? I checked the box when rendering. Could not find any info in the help file? How do I get the markers to transfer over?
    Wade Harrington replied 21 years ago 3 Members · 3 Replies
  • Edward Troxel
    April 29, 2005 at 4:51 am
    Are you sure the “Save Markers” box was checked on the Render As screen?
    Did you move the file after it was rendered? (Marker information is in a separate file)
    Edward Troxel
    JETDV Scripts
  • Larry Watts
    April 29, 2005 at 3:24 pm
    Did you try the button “import markers” in DVDA?
    Larry
  • Wade Harrington
    April 30, 2005 at 7:43 pm
    Thanks for the tips guys. No go. I did more testing. If I export to a new AVI file the markers are there and import fine into DVDA3. But will require a lenghty render. I would like to render it in Vegas 6 as the DVDA template but when I do and import to DVDA no markers. Even after hitting the add marker button, nothing. What am I doing wrong? Or is it not possible to save the markers in the DVDA template in Vegas6.
