Activity Forums Compression Techniques Chapter markers display in Compressor preview window but not in compressed Quicktime
  • Chapter markers display in Compressor preview window but not in compressed Quicktime
    Posted by Tom Donnelly on October 1, 2008 at 6:22 pm
    Hi all:
    Sorry, some Final Cut references here to put my compression prob in context…
    I am exporting a self-contained movie using setting “Show DVD Studio Pro Markers” – the sequence and of course the exported file are ProRes codec.
    When I open the QT outside of FCP, all the chapter markers are there in Quicktime viewer window (lower right, popup that allows me to jump to points in the movie)
    Next I import to Compressor – All the markers (edit point markers as well as chapter markers that I have set…) DO show up in the Compressor preview window. All looks good…
    I encode an h264 QT from compressor – but in the encoded QT, there are NO chapter markers present!
    I attempted a workaround of extracting the text track from the original exported QT and “Adding to movie” of the h264 QT using quicktime. Then I turn off the text track but keep on the popup that says Chapters > Text Track under “Other Settings” in the properties window of the h264 QT. The chapters are then visible in the lower right of the viewer window. BUT – when I close the movie and “save” then re-open, they are gone…argh!
    It has to be user-error, but I feel like I’ve covered all bases and searched this forum for similar problems, but still in the dark.
    Help!
    Jeff Coleman replied 16 years, 7 months ago 3 Members · 3 Replies
  • Daniel Low
    October 1, 2008 at 7:12 pm
    Are you using compressor 3?
    Have a look at step 8:
    https://www.apple.com/quicktime/tutorials/chaptertracks.html
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Tom Donnelly
    October 1, 2008 at 7:28 pm
    Thanks, that is super-helpful.
    I also found that I had not been setting each FCP marker to be a “chapter marker” in the marker dialog box (hit “m” twice). Once I did this everything worked smoothly even when batching with compressor…
  • Jeff Coleman
    January 28, 2010 at 8:35 pm
    [Tom Donnelly] “I attempted a workaround of extracting the text track from the original exported QT and “Adding to movie” of the h264 QT using quicktime. Then I turn off the text track but keep on the popup that says Chapters > Text Track under “Other Settings” in the properties window of the h264 QT. The chapters are then visible in the lower right of the viewer window. BUT – when I close the movie and “save” then re-open, they are gone…argh!”
    The markers don’t flow through using Matrox’s MAX.
    The workaround mentioned above and referring to Step 8 below doesn’t work. A couple of times I got it to take the track but as mentioned above the markers didn’t show when re-opening the movie.
    Is there anyway to get the markers to show up when you open the movie?
    QT 7.6.4
    OS 10.5.8
