Channel split
Hi im new to the software… and i was wondering how i would go about isolation specific channels on a peice of clip… e.g. remove or isolate RGB colours… the effect im tryna go for is the anaglyphic look..
i have seen this tutorial for photoshop https://www.youtube.com/watch?v=KvTMv90GOXk so i thought i could transfer the method to final cut.. help would be appreciated e.g. if theres a better way… or the above if it would work.
thanks
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
