Activity Forums Apple Final Cut Pro Legacy channel split for composer – plse help!
  • channel split for composer – plse help!
    Posted by Paula Stein on July 8, 2008 at 2:33 am
    Delivering for the composer:
    I need to make dialogue split to the left channel, the music to the right channel for our composer. .
    I have 14 tracks and I did a stereo mixdown for dialogue and a seperate mixdown for the music.
    So now I have 4 tracks total on the timeline.
    That is about as far as I got! I tried to pan in the audio mixer tool but couldn’t figure it out.
    Please help…not sure the best way to go…
    Paula
    “A journey of a thousand miles must begin with a single step.” ~Lao Tzu
    Jeremy Garchow replied 18 years, 1 month ago 3 Members · 6 Replies
  • Bouncing Account needs new email address
    July 8, 2008 at 12:48 pm
    Make a dupe of the timeline and, on the dupe, individually pan the tracks to separate channels, as needed.
  • Jeremy Garchow
    July 8, 2008 at 3:11 pm
    Do you need to provide two tracks of dual mono, or four tracks of two stereo pairs?
  • Paula Stein
    July 8, 2008 at 3:23 pm
    I am not sure about that. Here is what he emailed me:
    >>I need the dialogue split to the left channel, the music to the right.
    He wants to be able to turn the music off or on separate from the rest of the tracks.
    thanks,
    Paula
  • Jeremy Garchow
    July 8, 2008 at 8:31 pm
    OK, we’ll assume a dual mono mix, then (that means everything he’s doing will be mono, hope he’s okay with that).
    First dupe your timeline and attach the name DualMono to it. Then open the sequence settings by hitting command-zero. Then find the audio outputs tab. Change the ‘Grouping’ to Dual mono and hit okay.
    Then go back to your sequence and right click underneath the track lock on the very left hand side of your sequence. You should see a little drop down menu come out. For whatever track you have chosen whether it’s voice or music (let’s say it’s voice) go to Audio Outputs and choose 1, then do that for every track that has voice on it. Then go to your music track and right click underneath the track lock and choose 2, then do that for every track that has music on it.
    Now when you play your timeline, Voices will be on Channel 1 and music will be on channel 2.
    Make sense?
    Jeremy
  • Paula Stein
    July 8, 2008 at 10:20 pm
    Jeremy,
    It works like a charm.
    And your directions are excellent.
    Paula
  • Jeremy Garchow
    July 9, 2008 at 1:06 am
    Glad you’re up and running.
    Just in case this comes up, you can make a four track output (that’d be a stereo voice track and a stereo music track) by changing a few settings. In the Audio Outputs tab of your sequence settings, you can change the output number to four and leave the outputs at stereo. back in your sequences, right click under the track lock and select 1&2 outputs for your stereo voice tracks and 3&4 outputs for your music tracks.
    Make sense again?
    Jeremy
