Activity Forums Adobe Photoshop Channel Mixer
  • Channel Mixer
    Posted by Orthanc on November 1, 2005 at 8:29 pm
    How come, that when I use the channel mixer to create a monochromatic image the result is always darker than expected?
    For example: If I just look at the red channel of an RGB image, the resulting black and white image is much brighter than when I use the channel mixer and set it to 100% red and 0% green and blue.
    Richard Harrington replied 20 years, 10 months ago 2 Members · 2 Replies
  • Orthanc
    November 1, 2005 at 8:30 pm
  • Richard Harrington
    November 2, 2005 at 12:35 am
    Becuas you are placing the red Channel data into more channels when you are done…
    try Calculations comman instead
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
