Activity Forums Adobe Premiere Pro Changing X position keyframe is affecting Y?
  • Changing X position keyframe is affecting Y?
    Posted by Carl Movado on March 27, 2011 at 4:00 pm
    I’m trying to put some effects into an image inside a video. The effect that I’m trying to achieve is a Y-axis wipe where the image has two modified X-keyframes (i.e first X keyframe is at -100 and the other one comes about 5 seconds later at 100).
    However, leaving the Y-keyframe completely untouched, I see the image move up a bit, and halfway between both position keyframes, the y-keyframe moves up.
    those are the beginning and second keyframes.
    The issue goes away after I remove the last position keyframe (moves it back to (645, 295)
    I noticed that the problem only lasts for one keyframe if I duplicate keyframe 2 one keyframe before it (the frame it occurs in is between keyframe 2_1 and keyframe 2_2.
    I have linear checked, I Tried ease out and ease in, no luck 🙁
    Michael Tiemann replied 12 years, 4 months ago 2 Members · 2 Replies
  • Carl Movado
    March 27, 2011 at 8:48 pm
    Wow, that worked… I right clicked the keyframe, selected spatial Interpolation, and then linear!
    Can’t believe it was that easy.
  • Michael Tiemann
    May 4, 2014 at 7:24 pm
    Ugh! I am now having the same problem, and I think it’s not nearly as easy as you say. Adobe’s keyframe handling code appears to be written by a group of programmers who (1) don’t know each other, and (2) don’t really understand basic concepts of model-view-controller programming. I’m looking at the Position keyframe controller in the Motion part of Video Effects. The position is a two-dimensional parameter, meaning it can vary in terms of X and Y. The display of the keyframe values along the timeline show (and control) only the X parameter.
    Something has gotten into my Y parameter that is messing with my image position, but nothing I seem to try exposes where that’s coming from. All I see is the stupid X parameter, and neither a graphic indication nor a textual one that something is funky with the Y parameter.
    If only the XML output from Premier Pro could be easily parsed by humans, I might be able to tell what is going on. But now I have to decide whether to manually write down all the keyframes I currently set, delete them all, and try to re-enter, or what.
    Manifold Recording
    Pittsboro, NC
    https://manifoldrecording.com/
