Activity › Forums › DVD Authoring › Changing VIDEO_TS Volume Name upon Burning
  • Changing VIDEO_TS Volume Name upon Burning
    Posted by Jay Lee on August 5, 2006 at 5:09 pm
    Good morning all,
    Thought this was a simple issue but simply unable to find an elegant solution.
    I author and prepare my projects in DVD Architect 3.0 and then simply burn the resulting VIDEO_TS folder to disk via Roxio Disk Copier Vers. 7.
    The volume name I enter in DVD Architect does not burn on to the disk which simply appears as
    Jay Lee replied 20 years, 1 month ago 3 Members · 4 Replies
  • George Wing
    August 5, 2006 at 7:08 pm
    DVDShrink will let you burn an IMAGE to your hard drive, and also let you give it a volume name…
    Then you would just need to burn the DVD Image to disc…
    btw, which version of DVD Architect are you using (Studio or Full)? I thought the FULL version allows you to burn the volume name in the “Make DVD” step…
    Regards,
    George
  • Jay Lee
    August 5, 2006 at 9:37 pm
    Good afternoon George,
    Thank you for taking the time to write.
    I am using the full version of Architect 3.0. And yes it does give you an opportunity to input a value for volume name in
  • Anoni Moose
    August 6, 2006 at 6:41 am
    AFAIK the Volume Label isn’t in the VIDEO_TS stuff. When burning a DVD from “Nero Burning Rom” (what I use, because I’ve been using it forever) you can just type in the Volume name in a box on the Label tab of the Compilation Properties. Have done it, works fine. But it’s not a “disk copying” thing, it’s a “DVD-Video” project and you drag your VIDEO_TS directory into the project and then usually just edit the volume label there, although one can do it the properties as well as mentioned above.
  • Jay Lee
    August 7, 2006 at 9:25 am
    Anoni,
    Thank you for writing. I see……the volume name is not embedded in the video_TS files, thus a “copy” will not add a volume name. Shall try Nero.
    Thanks for the suggestion.
    Cheers,
    J
