Activity Forums Adobe After Effects Expressions Changing Values in a Precomp
  • Changing Values in a Precomp
    Posted by Jaime Matthew on September 23, 2020 at 11:26 pm
    I’m trying to do something that seems relatively simple, but it’s beyond my skills with expressions.
    I have a layer in a pre-comp that I want to be able to scale (and set keyframes) from the master comp so that I can set the timing in the main comp (and possibly impact multiple precomps at the same time).
    I won’t know the durations of the shots ahead of time, so being able to put the keyframes in the parent shot will save me a world of grief in these templates.
    Andrei Popa replied 5 years, 11 months ago 2 Members · 1 Reply
  • Andrei Popa
    September 24, 2020 at 6:00 am
    This was my setup. If you change anything(comp name, precomp name, effect name) you must also change it in the expression.
    Main composition name = Main Comp
    Pre-comp name(as layer, this means as seen in timeline, not project panel) = Shot 1
    Add a 3D point effect to pre-comp.
    I named it CTRL.
    Now go inside the precomp and on the layer that you want the scale to be modified write this expression:
    myComp = comp("Main Comp");
    myLayer = myComp.layer("Shot 1");
    myEffect = myLayer.effect("CTRL")("ADBE Point3D Control-0001");
    myEffect.valueAtTime(sourceTime(time)+myLayer.inPoint);
