Activity › Forums › Adobe After Effects › changing value of multiple keyframes simltaneously
  • changing value of multiple keyframes simltaneously
    Posted by Anonymous on November 9, 2006 at 4:57 pm
    I have a composition with cars driving around from an aerial view and they are driving on a road that is one file as the background. However this background file with the roads on it has changed so now the cars need to be moved to properly match the road. If I selecte all the position key frames and move them it only moves it for the key frame that the time indicator is on. How can I have it change the value for all keyframes?
    Matt Hall replied 19 years, 10 months ago 2 Members · 2 Replies
  • Anonymous
    November 9, 2006 at 5:51 pm
    Thanks dave! But is there no way to drag using the mouse?
  • Matt Hall
    November 10, 2006 at 7:13 pm
    Another way to select all the keyframes is to park the indicator on one of the keyframes, then click on the property name (i.e. position or scale). It selects all the keyframes for that property. Also, when you are parked on a keyframe, you can click on the stopwatch icon, to delete all your keyframes for that property. Better than selecting them all and deleting, becuase it leaves you with with the keyframe value you were parked on.
    Matt Hall
    Hallway Media, LLC
    http://www.hallway-media.com
