Activity Forums Adobe After Effects Expressions Changing time from seconds to frames in expression
  • Changing time from seconds to frames in expression
    Posted by Obed Ampong on April 6, 2020 at 1:29 pm
    Hello,
    Please, the expression below has the time duration in seconds however I would like to change it to the number of frames.
    Thank you in advance.
    Regards,
    Obed
    function easeInOutCubic(t, tMin, tMax, value1, value2){
    b = value1;
    c = value2-b;
    d = tMax-tMin;
    t = tMin < tMax ? thisLayer.linear(t,tMin,tMax,0,d) : thisLayer.linear(t,tMin,tMax,d,0);
    t /= d/2;
    if (t <1) return c/2*Math.pow(t,3) + b;
    t -= 2;
    return c/2*(Math.pow(t,3) + 2) + b;
    duration = 1;
    start=[-2000,540,-2000];
    destination = [960,540,0];
    exit = [2000,540,-3000];
    middle = (inPoint+outPoint)/2;
    v = time < middle ? easeInOutCubic(time,inPoint,inPoint+duration,start,destination) : easeInOutCubic(time,outPoint-duration,outPoint,destination,exit);
    Darby Edelen replied 6 years, 5 months ago 3 Members · 3 Replies
  • Andrei Popa
    April 6, 2020 at 5:06 pm
    Change the declaration of duration variable. That first number is the number of frames.
    duration = 30 * thisComp.frameDuration;
    Andrei
    My Envato portfolio.
  • Obed Ampong
    April 7, 2020 at 8:55 am
    Hello Andrei,
    Thank you very much.
    Regards
    Obed
  • Darby Edelen
    April 7, 2020 at 6:27 pm
    There are also expressions to convert a value in seconds to frames and vice versa:
    timeToFrames(seconds);
    framesToTime(frames);
    Darby Edelen
