Activity › Forums › Apple Final Cut Pro Legacy › Changing time code on newly redigitized clips.
  • Changing time code on newly redigitized clips.
    Posted by Dan Mcguire on April 5, 2017 at 12:49 am
    Folks, I have an SD timeline and I recently redigitized, to HD, all the original tapes.
    The timecode is not identical. Here is a picture of the SD file next to the HD file.
    Is there a way to re-write the TC on the new HD files to match the TC on the SD files? Thanks.
    Do I need to go to the same point on both tapes – for example, where there is a camera cut, to find the difference? There isn’t any slate on the footage. The same point on the SD file is 00:05:54;19 VS on the HD 00:05:57;11
    THANKS
    DAN
    Dan Mcguire replied 9 years, 5 months ago 2 Members · 3 Replies
  • Dan Mcguire
    April 5, 2017 at 1:15 am
    Just tried to use the FCP7 function of Modify->Timecode and it did not offer the option of a 29.97 time base – only 30fps. Why is that?
  • Nick Meyers
    April 5, 2017 at 11:29 pm
    while FCP can change the timecode,
    it can’t change the time base,
    you need to run the clips through Cinema Tools to “Conform” them to a new frame rate.
    i never work with those frame rates myself, living in PAL land,
    so there may well be other things going on i can’t identify,
    like did you capture the clips correctly?
    nick
  • Dan Mcguire
    April 6, 2017 at 12:04 am
    Thanks. I did not know that. I will look into that.
