Activity Forums Adobe After Effects changing the value on multiple key frames simultaneously
  • changing the value on multiple key frames simultaneously
    Posted by Mike Cantor on November 15, 2011 at 4:06 pm
    I have layer with about a hundred keyframes for “Scatter” in the CC Star Burst effect. I would like to lower all of the keyframes by a certain amount. Of course, selecting them all and then scrubbing the value down does not do the trick — this just creates a new key-frame at the current position.
    Is there anyway to change the value of multiple key-frames in an effect as a group?
    Thanks a bunch,
    -mike
    Don Daedalus replied 8 years, 7 months ago 5 Members · 4 Replies
  • Todd Kopriva
    November 15, 2011 at 5:00 pm
    What you described should work: selecting multiple keyframes and dragging the property value. That is described here.
    I prefer to manipulate multiple keyframes in the Graph Editor, as described here.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Roland R. kahlenberg
    November 15, 2011 at 6:05 pm
    What you want to do involves a 3-step procedure – you’ve missed the second step, which is to ensure that the TCI is parked on an existing KF.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Ryan Rosario
    November 18, 2012 at 10:23 pm
    I am struggling the same way.. I did everything and it still didnt work..
  • Don Daedalus
    February 21, 2018 at 3:59 pm
    Working on with the graph mode for multiple keyframes, especially for coordinates (x,y) values, is really helpful. Thanks!
    -DHPD
