Activity Forums Adobe After Effects Changing the Trim Path style in a script?
  • Changing the Trim Path style in a script?
    Posted by Fabian Brugger on September 26, 2022 at 9:29 pm
    Hey, i am writing a script that makes keyframe and a trim path effect for multiple shape layers. I am almost done but can’t find a way to change the trim patch style from simultaneously, as its set by default, to individually. Is there any way?
    I tried it with this but didn’t work:
    var trimStyle = layers[i].property(“Contents”).property(1).property(“Contents”).property(“Trim Paths 1”).property(“ADBE Vector Trim Type”)
    trimStyle.addproperty(“Trim Multiple Shapes”)
    Any ideas?
    //My Script:
    var comp = app.project.activeItem;
    var layers = comp.selectedLayers;
    if (layers.length == 0) {
    alert(“You must select a layer”);
    } else {
    for (var i = 0; i < layers.length; i++) {
    if (layers[i] instanceof ShapeLayer) {
    var propertyOne = layers[i].property(“ADBE Root Vectors Group”).property(1).property(“ADBE Vectors Group”)
    propertyOne.addProperty(“ADBE Vector Filter – Trim”)
    var trimStart = layers[i].property(“Contents”).property(1).property(“Contents”).property(“Trim Paths 1”).property(“Start”);
    trimStart.setValueAtTime(0, 0);
    trimStart.setValueAtTime(2, 100);
    trimStart.setTemporalEaseAtKey(1, [ease1]);
    trimStart.setTemporalEaseAtKey(2, [ease1]);
    var trimEnd = layers[i].property(“Contents”).property(1).property(“Contents”).property(“Trim Paths 1”).property(“End”);
    trimEnd.setValueAtTime(0, 0);
    //tired it with this but doesnt work…
    //var trimStyle = layers[i].property(“Contents”).property(1).property(“Contents”).property(“Trim Paths 1”).property(“ADBE Vector Trim Type”)
    //trimStyle.addproperty(“Trim Multiple Shapes”)
    var propertyTwo = layers[i].property(“ADBE Root Vectors Group”).property(2).property(“ADBE Vector Transform Group”).property(“ADBE Vector Group Opacity”)
    propertyTwo.setValueAtTime(0, 0);
    propertyTwo.setValueAtTime(2, 20);
    propertyTwo.setTemporalEaseAtKey(1, [ease1]);
    propertyTwo.setTemporalEaseAtKey(2, [ease1]);
    var propertyThree = layers[i].property(“ADBE Root Vectors Group”).property(3).property(“ADBE Vector Transform Group”).property(“ADBE Vector Group Opacity”)
    propertyThree.setValueAtTime(0.8, 0);
    propertyThree.setValueAtTime(2, 100);
    propertyThree.setTemporalEaseAtKey(1, [ease1]);
    propertyThree.setTemporalEaseAtKey(2, [ease1]);
    Fabian Brugger replied 3 years, 12 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 27, 2022 at 12:04 am
    This quick test worked for me:
    app.project.activeItem.layer(1).property("ADBE Root Vectors Group").property("ADBE Vector Filter - Trim").property("ADBE Vector Trim Type").setValue(2);
  • Fabian Brugger
    September 27, 2022 at 8:53 am
    Thank you very much! It works.
    Also thank you for all the work you do on this forum! I red some posts of yours answering other people’s question and could learn from that!
