Activity Forums Maxon Cinema 4D Changing the transparency of one instance of a multi-part object
  • Changing the transparency of one instance of a multi-part object
    Posted by Hawkowski on May 7, 2006 at 7:34 am
    Imagine we have a relatively complex car object consists of multiple parts each assigned with a different texture.
    I want to put two instances of this car object into two different positions with different orientations and make one of them 50% transparent while the other appear in its original form.
    How can I change the transparency of one instance of a multi-part object (parts have different textures) while keepig the other instance unmodified?
    Roberto Hawkowski
    Hawkowski replied 20 years ago 2 Members · 3 Replies
  • Nolan Scott
    May 7, 2006 at 9:59 am
    Put a Display-Tag on your Instance-object
    and reduce the Visibility to your desired level.
    Cheers
    Nolan
  • Hawkowski
    May 7, 2006 at 1:47 pm
    Nolan,
    Many thanks !
    Kind regards,
    Roberto Hawkowski
  • Hawkowski
    May 9, 2006 at 7:58 am
    Thank you Nolan,
    Is it also possible (How:))to make that semi transparent instance glow?
