Activity Forums Apple Final Cut Pro Legacy Changing the sub-title text color over time.
  • Changing the sub-title text color over time.
    Posted by Arvind Kumar on March 21, 2008 at 4:52 am
    Hi friends,
    I’m new to FCP. Our company focuses on adding ‘Same Language Subtitles’ to songs.This sub-titling differs from the normal subtitles in a sense that the words are high-lighted as they are being spoken.
    For eg. “Good Morning” . This text would be in complete red color at the start.After 5 seconds, first word would change to white color.Then after another 5 seconds the 2nd word would also change to white. That is the text words should change their color overtime.
    Have a look at the sample video to see this effect in action:
    https://video.google.com/videoplay?docid=-3514442491374632719
    1.What would be the best way in FCP to achieve this?(We are having FCP 5.)
    2.What would be the preferable titling app?
    I saw LiveType . The inbuilt text generator of FCP?
    I have a text file with 50 lines.I would like the app to read this txt file and produce 50 sub-titles for each line starting from the first. Is this possible with the above applications?
    Any help is appreciated.
    Thanks for your time,
    Arvind.
    Matthias Halibrand replied 18 years, 5 months ago 2 Members · 1 Reply
  • Matthias Halibrand
    March 21, 2008 at 8:17 pm
    For subtitling I can recommend the SubBits Subtitler by videotoolshed.com.
    You can easily paste your lines there and then export to Final Cut.
    For how to achieve the effect:
    It doesn’t really matter which text-plugin, qualitywise I recommend Boris, if you use the SubBits subtitler there is a plugin for text included. I would lay to identical textlayers, change the color of the upper one and animate a four-point-mask over time to achieve the “decoloring”. This is pretty fast and easily configurable.
    Regards,
    MatzeHali
