Activity Forums Adobe Premiere Pro Changing the presets of a project
  • Changing the presets of a project
    Posted by Philippe Verdoni on January 13, 2009 at 9:21 pm
    I have failed to do the “Export to tape” of a project probably because I am trying to export the timeline on an NTSC Canon HV30 camcorder whereas the Project settings that I had selected when creating the project where HDV 1080i25 (50i) which are for editing at 25 frames per second. I have 2 questions:
    1 – how can I check the settings selected at the creation of the project ( I don’t know any PPro CS3 command to display the settings)?
    2 – is there a method to import an HDV 1080i25 (50i) project in a new HDV 1080i30 (60i) project?
    Thank you for your help.
    Jon Barrie replied 17 years, 4 months ago 2 Members · 1 Reply
  • Jon Barrie
    January 13, 2009 at 10:52 pm
    Open a New Project with the correct Seq settings and import the old project in. Find and open the original seq you were editing, it will now be running from the new projects settings.
    – Jon 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
