Activity Forums Adobe Premiere Pro Changing the length of the sequence
  • Changing the length of the sequence
    Posted by James Easter on December 16, 2008 at 5:10 pm
    Good afternoon all,
    I’ve pressed into service editing some videos with Premier Pro CS 3. I’ve scoured the online docs and google and for how to change the default project/sequence length when starting a new project or editing an old one.
    Currently when I start a new project the timeline goes from 0 to 13 min 39 seconds. For one project I know the clip I’m creating will be no longer then 10 seconds. How does one change the project setting so that the timeline will start at 0:0:0:0 and end at 0:0:10:0 ?
    I’ve tried the Project Settings, Project Manager, Sequence Properties, etc. I believe I’m lacking the correct vocabulary here and thus not finding what I need.
    Any help would be appreciated.
    ~ James
    Wouter Wynen replied 13 years, 8 months ago 3 Members · 2 Replies
  • Eddie Lotter
    December 16, 2008 at 8:28 pm
    The timeline is only as “long” as the end of the last clip.
    In other words, the timeline does not have an intrinsic length.
    If you cannot see the clip then it might be on a track above or below the timeline window. Scroll up and down to see obscured tracks.
    Cheers
    Eddie
  • Wouter Wynen
    December 23, 2012 at 12:28 pm
    I realise that the timeline length doesn’t really matter. But, it is annoying that the timeline is 1h long if you only need 1 minute. It’s a hassle to use the zoom bar etc… Isn’t there a way to make it shorter again?
