Activity Forums Adobe After Effects changing the frame size after the fact
  • changing the frame size after the fact
    Posted by Dustin Ward on January 14, 2009 at 5:18 pm
    I didn’t realize before i started working that the frame size i was using was a massive custom size! of course when i change the frame size now, the frame shrinks but the contents stay the same. How do i fix this problem without having to resize each individual element?
    Steve Roberts replied 17 years, 7 months ago 4 Members · 5 Replies
  • Dustin Ward
    January 14, 2009 at 5:28 pm
    haha thats awesome! i would have never thought of that.
  • Kevin Camp
    January 14, 2009 at 5:30 pm
    you could move the large comp into a new comp that is the correct size, then scale the large comp to fit. this should maintain all the layer positions relative to the large comp.
    you may also be able to change the comp size of the large comp, create a new null (layer>new>null) then temporarily parent all layers to the null (select all the layers, the use the parenting pick whip attach them to the null) and adjust the scale of the null to fit all the layers in the new comp size. then you can delete the null.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    January 14, 2009 at 5:31 pm
    dave beat me….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Greg Hahn
    January 14, 2009 at 6:19 pm
    Assuming your current comp is the same aspect ratio (4×3 or 16×9, etc) as what you desire, you could also run the “scalecomp” action script. This works pretty well and does all the scaling for you without the “null object”.
    click on “File”, then “Scripts\Run Script File…”
    The action script is in “scripts\(demos)” folder in your AE folder.
    Cheers!
    Greg
  • Steve Roberts
    January 14, 2009 at 9:00 pm
    Or … if all the layers are 3D, you could reduce the focal length of your 3D camera.
